How to hide the shadow of a part used as a sketch plane
Hello everybody,
for my sketches I often use an existing part as reference (plane) to create a new sketch.
I right-click on the surface of a part and choose "new sketch". So far, standard procedure.
In this sketch however, the surface of the part appears as some kind of shadow. It is possible to extrude this shadow.
And here Onshape drives me crazy: When I want to extrude from my new sketch, I frequently click on this shadow instead on the sketch. It is literarely on the same plane.
Also, the edges of this shadow act as non-construction lines. Meaning, I have sometimes little holes in my parts because one of these almost invisible edges runs through my sketch.
I spent some serious amount of time fixing parts. With increased complexity this is just not sustainable any more.
Any help would be very much appreciated!
Best Regards,
Michael
  • mahirmahir Member, Developers Posts: 1,321 ✭✭✭✭✭
    When you use a surface as a sketch plane, Onshape will always infer its edges. The only way I know of to avoid this is to create a separate plane or mate connector on that surface and use that as the sketch plane instead. Specifically, the MC method is pretty straightforward since you can create MC's on the fly without adding extra features to the feature tree.
    edited March 2021 Answer ✓
    In my case, a Mate Connector will still show up in the feature tree.
    It does add additional bulk in the feature tree, which isn't nice. But as long as it works, I will save a lot of time.
    Adding a MC as a separate feature will definitely make it show up in the feature tree. But if you use the on-the-fly MC button next to the sketch plane box, there shouldn't be anything extra showing up in the feature tree.
  • michael_schaubmichael_schaub Member Posts: 9
    Hi Mahir!
    Thank you for your response. This is a good workaround.
    Thanks a lot!
    Michael
    Thanks a lot!
    Thats great!
Howdy, Stranger!
