Embedding version information with SurfaceText
burt_harrisburt_harris Member Posts: 7 ✭✭
edited March 2021 in Drawings
I'm creating and testing a significant number of prototypes using 3D printing.   I'd like a way to put version information in surface text automatically.   Is there a way to get this with an expression?
Experimenting for a solution, I found there's a predefined variable named #ID_COUNTER.   So far, it has always returned 12, even after I create a new version.   Interesting, but no cigar.
  • burt_harrisburt_harris Member Posts: 7 ✭✭
    edited March 2021
    It looks like I somehow created this question in "Drawings".   Is there a way to move it somewhere more appropriate?
  • michael3424michael3424 Member Posts: 758 ✭✭✭✭
    I've done something in the past using configurations.  It's not automatic but does save some time compared to manually chaging the surface text for each iteration.
    @burt_harris - I don't think this is possible to automate because all editing is done in a "workspace" which, by definition does not have a version. Then, once you create a new version, you can no-longer edit the model.
    Maybe this should be an improvement request? I would see it working somewhat like Revisions on drawings work. In the workspace the Rev table lists the next revision in the scheme with an * next to it. Once released, its updated with the actual revision and read-only.
