Linear Pattern Sketch Feature
I have found the linear pattern tool in sketch among the hardest to control. There's no creation dialog box or quick tip like with similar tools and once created, there seems no way to edit the pattern. Are there features I'm just not seeing?
Here is the documentation page:
https://cad.onshape.com/help/Content/sketch-tools-sketch-pattern.htm
In general, I recommend using the pattern feature if possible since those are more configurable and stable in general. Sketch patterns are best if you need to define the spacing based on the position of some instance or you need to delete/edit specific instances.
https://cad.onshape.com/help/Content/linearpattern.htm
