How can I extrude around the outside of a round face?
brian_sweet
Member Posts: 12 ✭
I have a basic ring the I would like to remove a diamond shape pattern all the way around it. I was able to do one with a tangent plane. tut I am at a lose how to do that many times around it. I thought multi plain might be the answer, but either I am doing it wrong or it isn't meant do what I am trying to do.
Here is my start:
https://cad.onshape.com/documents/665c0ed5ebd690d47908381b/w/8d731be1cdd8f44a59e9eede/e/0157ae2f40c73d8a1d0e4ec2
As an example, let's say I want to have12 diamonds around the ring evenly spaced.
Any help to this newbie would be greatly appreciated.
Here is my start:
Feature pattern.
Little more work on this example but the holes don't overlap like a straight extrude.
https://cad.onshape.com/documents/1249a62cc918c7b9b008fbec/w/416e108a56778eeea8823df6/e/8252077a16e0a785453855ae
1 -
@brian_sweet, a few key mathematical tools for this endeavor are:
- Circumference = PI * D
- Arc_length = R * Theta (with the angle specified in radians)
- Use the floor() function to truncate any calculated pattern count to a whole number (i.e. round down)
How to implement the math functions depend on what your trying to do. Explicitly defining a variable for every parameter overconstrains the problem and will result in mathematical or geometric conflicts. For example #Ring_size, #Lattice_width, and #Diamond_size can potentially conflict with one another. #Pattern_Count has the potential to further conflict with these. Imagine red ink in your feature-tree or lattice lofts overlapping / spilling off the top or bottom.You will have to choose a small number of INDEPENDENT variables and allow all other parameters to float (automatically scaling according to the specified independent variables).By way of example, here is a simplified version of your model with the upper and lower triangle lofts omitted for clarity: https://cad.onshape.com/documents/02f15cc45132085896aa6f5b/w/9c9fc970396d7e20ae17cee1/e/8c8c76e0ef28eb38b5c8f346. Most of the features (Extrude 1 height, pattern count) scale directly from #Diamond_size.Happy modeling!1 - Circumference = PI * D
Feature pattern.
Thank you, that was so simple. Thanks for giving me the opportunity to learn0
1 -
That's even better. I was messing around with the file, but here is the design I am looking for using your loft idea:
https://cad.onshape.com/documents/315f6616a46a1eceda8a161b/w/e8f39b6733b49dc2eaa1453b/e/38cac24dabd0a93aea4b98db
Not sure you you want/can to provide me any more additional advice, this is more a mathematical calculation help (My college Trig courses are long wiped from memory...lol).
When doing the circular pattern with this design, I am tying to figure out how to adjust the pattern count to the lattice spacing and to make the spacing even. With pattern count at 25 and spacing at 2 it looks close, but you can see the spacing before then next patter starts is a little bigger.
My goal would be to be able to change the diameter for a larger/smaller bracelet size and have the lattice spacing even.
And Lastly thank you for your help. I started 3d printing a year ago and want to design things, tinker cad was to basic and OnShape had a bit more learning curve. But I can't tell you how much (even when I get frustrated when it doesn't work) I love working on designs in OnShape0 -
This was so helpful. MANY THANKS!0
