I cannot get a fillet to work on a letter and I'm not sure why.
emerson_lavallee
Member Posts: 15 ✭
There is this one letter on the back of a penny that I cant seem to get the fillet command to work on. Could someone try and troubleshoot the problem for I've been stuck on it all-day?
Thank you!!!
https://cad.onshape.com/documents/9658b000937be9c6c444c930/w/c3452c49d7564c096a1f0b8c/e/6beedf90e7eef1399d3f3760
Thank you!!!
MichaelPascoe
Member Posts: 2,688 PRO
Two of the spline points were too close together. This caused that corner of the "A" to be unstable for fillets. I spread them apart a small amount so that it works now.
https://cad.onshape.com/documents/73d139f82156c6c583c6071a/w/9cc28f70b1a71d1fbf8bf621/e/09aa8330dd4c582ca91b58db
CADSharp - We make custom features and integrated Onshape apps! Learn How to FeatureScript Here 🔴1 -
bruce_williams
Member, Developers Posts: 842 EDU
emerson_lavallee
.00172" radii?!? You are pushing the limits! I do not think CAD will allow much smaller....
For your problem - I found two points virtually on top of each other. Moved them apart and it worked.
Amazing seeing the detail on the pics of pennies. What artist the engravers are! Thanks for sharing.
www.accuratepattern.com0
Touche! so we are probably even.
We need a thing like Slack that shows when somebody is typing.
That would be nice. Especially for longer answers.
