What does "Some of the geometry intersects itself or is degenerate" mean
robert_miller164
Member Posts: 2 ✭
I am new to OnShape. I have a .dwg file exported from Illustrator that OnShape is having trouble with. Part of the file works and part doesn't. I've been trying different things but nothing helps. Even if I bring it in as two different files, the one that works is good but the one that doesn't gives me the above error. I've checked for grouping, non-continuous lines, fill, non fill, etc., etc., etc.
Attached is the .ai file. The "r" in the logo works. The "m" gives me the error above.
Not sure about the errors, but I don't think the files have attached. Perhaps you could share a public link to the document with the two files in?Engineering textbook: https://hwh.stephenteacher.com/txtbook.html0
I purchased a dxf graphic and was trying to use it in on shape.
Here is the test:
https://cad.onshape.com/documents/cbbbd6682a0090b36f9c49ba/w/dd767eed9de6522824d3286a/e/6c79d14d242f6b7e8271a0f7
Let me know if anyone if anyone has an idea0 -
Not sure where the problem is exactly but I would start by fixing all the "open" sketch bits. This featurescript is great for this:
https://cad.onshape.com/documents/4fa113c6594cd037bfa214da/v/e5f9020158b188b1ec33530d/e/4eb9378eccc7b7a0261b6f14
Also I've found the issue, it's in this area:
If you box select like this and delete it gets rid of the error:
To make sense of the error message: a curve that intersects itself is something like a single curve that crosses itself like a figure 8 or ichthus. A curve that is degenerate means it's a zero-length curve, like a line with coincident start and end points (I'm less certain about this one, but I think it's something like that). It's possible that you've got a small error in Illustrator, or that it made one in translation.0
How is the FeatureScript implemented? I don't see any documentation on this particular script.
