Planes
teddy_pessagno
Member Posts: 38 ✭✭
Hi @teddy_pessagno when you mention Plains you mean Plane, if that is the case in help you can find good info about working with them https://cad.onshape.com/help/#cplane.htm?Highlight=planes
EDIT: Apologise for the lack of dimensions and detail
Nicolas Ariza V.
Indaer -- Aircraft Lifecycle Solutions8
Nicolas Ariza V.
Indaer -- Aircraft Lifecycle Solutions8 -
@nav ,
Thank you. That will work perfectly. Plane is correct not plains.
I was thinking of sketching two circles, connecting them with lines, then trimming. I like your way better.
Thanks
Teddy_P
Depending on production technology, the semicircular-ended keyway will sometimes be preferred.
I am short on time right now to post a model, but there are neat ways to model such a keyway which also work for the smaller cutter situation (4 fillets at 90 deg, instead of two at 180 deg) and which automatically make the slot the correct (standard) depth0
