Right-click rotate shortcut keeps opening menu
tony_459tony_459 Member Posts: 206 ✭✭✭
edited April 2021 in Using Onshape
This didn't use to be a problem. If you wanted to rotate the 3D view, you would just right-click and rotate.
And this still works, but now when I release the right-click, the context menu opens, and this happens many many times per minute. So now I need to keep an extra finger on the ESC button just to close the context menu after I right-click rotate. It doesn't help that I tend to accidentally release the right-click when the cursor is just over a context menu option, so I wind up confirming sketches, hiding parts, etc, and having to undo those accidental actions.
I'm using the very latest version of Firefox on a very capable Razer Blade laptop that has worked fine with Onshape before.
Am I the only struggling with this?
    Seems to be working fine over here ¯\_(ツ)_/¯
  • AnotherOnshapeUserAnotherOnshapeUser Member Posts: 29 PRO
    Same problem. Popup shows up on rotate and then selects something unwanted. No apparent solution?
