Extrude to opCreateBSplineSurface is not robust
brandon_furtwangler
Member Posts: 12 ✭
I have a feature that adds a opCreateBSplineSurface, and then in various places I need to extrude up to this surface. My extruded sketch is always within the XY bounds of the surface, and I'm extruding from below the whole surface up to the the surface, so this operation should never fail.
In practice, I have ~300 different unique configurations of my part & about half of them fail to extrude for unknown reasons.
For example, this configuration works just fine:
While this slight variation on the top surface shape causes the extrude to fail:
There seems to be little rhyme or reason to it - it just appears that intersections with opCreateBSplineSurface are buggy.
Here's the document. I'm in the Talon Caps part studio & this is with the 'Homing' configuration enabled. Feel free to use the various configuration settings as test cases for a more robust implementation.
https://cad.onshape.com/documents/0834293e74af4c6a396f8eab/w/f486ecb436e3b08b4a3a7007/e/eba3ef0267cc4c6c5161806e?configuration=List_NyThPuBqySRLMD=homing;List_f6j0re8WqI0TiW=Default;List_hn0GuVRdS6CNqY=Copy_of_edge;List_tfUVaJqjqApmxI=u1
