Is it possible to change/control/override the dimension line angle?
StephenG
Member Posts: 379 ✭✭✭
I have a section view where I want to set/control the angle of the dimension line to specify a measurement.
How does one create the above red dimension?
The only way I know of to get a non-horizontal/vertical dimension, with respect to paper (drawing) orientation, is to use a 2 point dimension and to initially position the nominal between the 2 points selected, or select a line to create a dimension along its length were the dimension line is parallel to the selected line.
Or, could the centerline tool give you a line perpendicular to the opening (parallel to your leader lines)?
Centerline tool is of no help. Line creation functionality in drawings is utterly lacking (and this is being kind to the product).
I cannot think of a 2D CAD system I have used in the past that does not offer some option to orient the dimension line from the normal implied line-to-pt/horizontal/vertical/pt-to-pt orientations. I was also a little surprised (disappointed) that the notion of horizontal and vertical was not inherited from the parent view. It appears that horizontal and vertical are always with respect to the drawing template.
Note: Section D-D in this drawing is being used to document deviations in a loft feature being developed to produce a uniform chamfer.
