Binary arithmetic/operators in featurescript?
mark_sherriff693
Member Posts: 2 EDU
Hi,
I'm looking to be able to do things like XOR, bit shifting and bit masking inside a function in FeatureScript, as part of a generative algorithm to draw a pseudo Hilbert curve.
Unfortunately, this looks like it's not possible, as FS gives no binary operators or binary types - is there a known way to do these sorts of things in the community?
The closest I can get to anything resembling it in decimal is representing a right shift as "floor(value / 2)" - but this is only one part of the algorithm.
Thanks
Thanks
@mark_sherriff693
There is no binary operators in FeatureScript. You will have to do your own functions for that. Also, all numbers in FeatureScript are represented as double-precision floats, so you will lose some precision as soon as you go above ~53 bits.0
