Adding Roll Dimensions
spiritrider
Member, csevp Posts: 32 PRO
in Drawings
In the Drawing Mode, there is no way to easily create a roll dimension to make it easier for a machinist to measure an angle. I can create a sketch in the part studio but I would like to have that info on a drawing. Currently, I do the roll dimension data in part studio, do a Screen Print, make a JPG file of the sketch, then import it into the drawing. This is a lot of work that could be done with a real sketch feature in the drawing mode to create roll dimensions easily.
Create your sketch in the part studio, then right-click on a drawing view and select "Show Sketches". This will allow you to select on or more sketches to display with that drawing view.
