can I check globally my design?
nicolas_7
Member Posts: 8 ✭✭
Hi all, I'm a noob here.
I made a design were some features tend to fail when I edit the history. To manage the size of said history, I spread everything to various part studios, so I don't have a global view of my history.
Here is my question: is there a way to check my whole design, to quickly find if any fillet, draft or boolean operation is red anywhere in the design, and that none of my studio has a sketch or feature dialog open?
If anyone wants to know what I did and criticize: https://cad.onshape.com/documents/2ce135642af145c7862748ec/w/dd904e6ae6aa42dd8ade1920/e/18942358e0924e02a8a54ea3
It's my first design in Oshape, so everything is made the way I could.
I guess what you want is tools such as design checker in solidworks or Geomcheck in Creo to check your design if it meets all requirement such as no failed features, no suppressed features etc. But at this point of time Onshape do not have this functionality. Onshape is working on it to implement the same as soon as possible once main features for modelling process are well defined to fulfill all requirements of modelling. You can also put it as improvement request.
Currently there is one tool for work space comparison where you can compare designs in work spaces created by different users. See this link https://www.onshape.com/cad-blog/tech-tip-comparing-design-changes-in-onshape5
Currently there is one tool for work space comparison where you can compare designs in work spaces created by different users. See this link https://www.onshape.com/cad-blog/tech-tip-comparing-design-changes-in-onshape5 -
Thanks for your answer, I guess it's an obvious feature, no need to add a ticket for it. I'll have a look at the version system soon I think.0
