Exploded View Creation Workflow
S_RegulaS_Regula Member Posts: 95 PRO
I'm wondering what kind of workflows are used by other OS users for handling exploded views in assemblies. We create assemblies and the accompanying exploded view(s) to use on drawings. However, since our products are mostly in the development stage, there are constant changes happening to the assemblies, mainly parts being added/removed. When this happens, it is quite the task to update the exploded view(s), especially when a part is removed and each explode step that included the now removed part turns red, indicating a missing entity. To fix the "faulty" exploded steps, I have to edit each step and remove the missing parts/add the new parts. When there are 20+ steps that indicate errors, this becomes quite time-consuming. I have not discovered a workflow to make this often cumbersome task more efficient. Any feedback is appreciated. TIA...
  • shawn_crockershawn_crocker Member, OS Professional Posts: 914 PRO
    I'm thinking of two ways. One way would be for Onshape to develop an advanced AI that's able to read your mind through your webcam and just automatically recreate the explode views based on what your thinking.  😉. Another way would be, don't bother with explodes untill the design it done? I usually find explodes only useful for drawings and drawings only useful when the design is done. I do know what you mean by explodes being annoying when changes do have to be made after the fact though. It would nice if explode steps were like SolidWorks where you could dig into the step and see what's inside without having to activate each one.
