Editing OBJ files?
chris_wood711chris_wood711 Member Posts: 2
Hi, I'm pretty new to onshape, so forgive me if this is a silly question!  I've imported this OBJ file shown in the picture below and want to edit it.  What is the best way to go about this?  I've seen a youtube video where you create planes and sketches using vertices to essentially copy
    Sounds like you best start with the 'Learning Center' under the question mark.
    There are no direct editing tools for mesh data in Onshape today. As you mention, using the mesh data for reference and recreate in Onshape. Not a trivial exercise.  :)
    www.accuratepattern.com
  • EvanReeseEvanReese Member, Mentor Posts: 2,824 PRO
    What would you hope to change about it?
