How to punch holes in existing extrusion
ruth_ivimey_cook
ruth_ivimey_cook Member Posts: 14 ✭
edited June 2021 in Community Support
In Onshape I have a model that has some 'pads' (electrical terminals) lying on top of a PCB (board), and these pads should have holes in them. The sketch for the pads doesn't have the holes, because another sketch, for the PCB body, has them (& also defines the edge of the PCB). It was easy to get holes in the PCB body (I just didn't extrude some faces, but not quite sure why that worked). Conversely, the sketch for the PCB doesn't have the pad shapes because the pads are on top, not through.
The sketch for the holes, and the sketch for the pads, have differing offsets, but are parallel to each other (1.5mm gap), because it is the extrude distance of the holes that forms the plane of the pads.
How can I make the holes in the pads?
I have tried using the Boolean tool, but I cannot make it work because it won't accept either a sketch or an extrude as input. I have tried several combinations of extrude operation (subtract seems useful) but cannot find one that works. Some combinations get the pads right, but obliterate everything else in the model :sa My model is public: https://cad.onshape.com/documents/a5c2a279e49528c89c09d0b2/w/dc89a9141b1c67c5842bdca1/e/54061859f71e3093f5c71781
