Moving/Importing multiple STL files into a single part studio
I have 3 STL files (imported as meshes/composite parts) that I would like in a single part studio so I can line them up and design a single piece off of them. However, you don't get the option to import them into one part studio when you select multiple induvidual files. I also tried zipping all 3 files into a zip file but got the error: "Cage.zip was not translated. Translation is not supported for zipped STL (.stl) files."
You can see the three part studios in the bottom tabs: Cage-Back, Cage-Middle, Cage-Front. I would like these STL's in the same part studio. Any information would be appreciated.
https://cad.onshape.com/documents/6d306c30df539c19a1497630/w/0223a23cd4835ddb76eda6da/e/42c51283241340910e7922cc
Cobalt_Echo Member Posts: 31 ✭✭
Nevermind, I'm an idiot. In case anyone else stumbles across this...3
