typeof?
brooke_spreen
brooke_spreen Posts: 115 ✭✭✭
Is there an analog of Javascript's "typeof" in Featurescript?
In other words, is there a way to ask the open-ended question "what is the type of this variable"?
Note that this is a different question than "is this variable of the type 'myType'", which returns a boolean.
As an example, when debugging, it would be very useful to do:
println(typeof myVar);
example output:
Array
or
Query
Design Engineer | Anerdgy AG
  • konstantin_shiriazdanov
    konstantin_shiriazdanov Posts: 1,221 ✭✭✭✭✭
    Sadly there are no capability like this in fs. Only if tests, not even case/match statements, though these keywords are reserved so it may come once.
  • brooke_spreen
    Bummer! Maybe one day the typeof will come as well...
  • Jacob_Corder
    Jacob_Corder Posts: 141 PRO
    you can use this
    If(myVar is Plane)
    else if(myVar is Query
    elseif(myVar is Array)
    else if(myVar is Map)
    it works for any type and passes through the type check function of each type.
