Issue with dimension tool when trying to set angle
joseph_abenhaim
Member Posts: 2 ✭
in Drawings
I'm trying to set the angle of the rectangle using a constraint as pivot as demonstrated here. With or without constraint on the inner rectangle it throws the same error.
Note: when you create a dimension and it is grey, it means it is a driven dimension. It doesn't actually define or constrain anything in your sketch, but gives a measurement between constrained things. Trying to change that dimension overconstrains the sketch.
Lead Mechanical Engineer @ Healing Innovations
