cant make a solid revolve
sebastian_saavedsebastian_saaved Member Posts: 2 EDU
every time I revolve an object. like clicking one line and then the dotted line to revolve it about 180 degrees. but every time I do that the inside is hollow. I want to revolve an object 180 degrees and for it to be solid.
  • John_P_DesiletsJohn_P_Desilets Onshape Employees, csevp Posts: 273 image
    @sebastian_saaved Without seeing the example I am assuming that the sketch you are revolving is not a closed profile. If you use a solid line instead of a construction line to revolve around it will be a solid.
    Open profile
    Closed profile
  • Jake_DelanoJake_Delano Member, Onshape Employees Posts: 43 image
    Could you please post a link to your document?
