weldments
when will the weldment feature, similar to solidworks, be available?
what is the workaround currently to model frames in 3d space?
I assume you have to create a sketch on each plane that you want to add beams and create a separate beam feature on each of those planes. do you know if Onshape will be adding 3dsketching and other weldment improvements soon?
https://cad.onshape.com/documents/bb6bab9a0aca645543985982/w/0b10c14399f470012642353e/e/5c299d97d0b8c63c35a6a847
