weldments
rick_conard
Member Posts: 30 ✭✭
when will the weldment feature, similar to solidworks, be available?
what is the workaround currently to model frames in 3d space?
See the Beams feature here: https://www.onshape.com/en/features/custom-featuresSenior Director, Technical Services, EMEA0
Neil, thanks for your reply. That looks like it might fill the need but I don't fully understand how to use it. Do you have any more instructions?
I assume you have to create a sketch on each plane that you want to add beams and create a separate beam feature on each of those planes. do you know if Onshape will be adding 3dsketching and other weldment improvements soon?0 -
Here's a sample to look at
https://cad.onshape.com/documents/bb6bab9a0aca645543985982/w/0b10c14399f470012642353e/e/5c299d97d0b8c63c35a6a847
The old Silicon Graphics logo 😀Senior Director, Technical Services, EMEA0
I see how it works, thanks for the replies.0
