I want to mat 3mm tall and 2.10mm long cylinder (hole) onto a square face. How to do this?
miguel_abaddon
Member Posts: 2 ✭
I have a rectangle piece rotated at exactly 45 degree that I want to align a 3mm tall and 2.10mm long cylinder to work as a hole onto exactly at the central position of the face. How do I achieve this?
https://www.mediafire.com/file/dxoxn9i9h89j01q/ripping+off+headband+(1).stl/file link to stl including the cylinder pieces.
To make a hole sketch a circle on the face you want the hole then either extrude remove or use the hole button?
