Counter sinking a hole
mark_cunninghammark_cunningham Member Posts: 78 ✭✭
I've been trying to figure out how to counter sink a hole in my part but cant seem to do it with a curvature. Any help is appreciated!
 https://cad.onshape.com/documents/8f3409273cc83b210308d126/w/c89c902f9dcdf06d5c7ab26a/e/81ac2f9df4e77d6c556818d6
  • EvanReeseEvanReese Member, Mentor Posts: 2,865 PRO
    Have you tried using the Hole feature instead of extruding a circle? It'll size it for you based on what size of screw you want, and can add the countersink too. If you end up making a drawing of the part, using the hole tool also will let you use the hole callout in the drawing which will properly spec the hole.
