Drawing Dimensions - asking for a better way - a radius on an arc
john_hauck
Member Posts: 52 PRO
Question:
I created a barrel - 14mm maximum diameter, 10mm diameter at the ends.
On the left side of the barrel, I added a 3mm radius (parametric step after the revolve).
The dimensions on the drawing are not really helpful with ugly numbers like 11,53mm and 5,82mm.
I think this would be easier if the "Virtual Sharp" would work with one side being an arc.
How can I do better with the current version of OnShape?
Source:
https://cad.onshape.com/documents/7bff7baec4f1a88cf83647ca/w/5cdfa2277f4323951ead4084/e/51c94d6a9ff532e2f761a61c
Drawing:
Source:
Drawing:
alnis Member, Developers Posts: 452 EDUAdd a sketch with the point/extension lines/other annotation in the part studio, then show that sketch in the drawing (right click -> show/hide -> sketches -> select the sketch)
https://cad.onshape.com/documents/7ece7a5312316cd938c53f1a/w/23a7f0edba1a92ea096257f6/e/771032e7a63a5d877c3a1706
Get in touch: contact@alnis.dev | My personal site: https://alnis.dev
@alnis is my personal account. @alnis_ptc is my official PTC account.1 -
PeteYodis Moderator, Onshape Employees Posts: 544We also have an improvement on the books to include arc entities in the definition of virtual sharps in drawing views. Something we certainly want to deliver on.0
