Material selection.
I have a part that does not have material assigned to it.  It is noted as a assy.  How do I get it back into parts so I can assign the material?
84 Campbell
  • alnisalnis Member, Developers Posts: 453 EDU
    Two options:
    1. Open BOM on the right side and double click the material to edit (or any other property) (you may need to add the material column):
    2. Alternatively, you can right click the part and select "Switch to [part studio name]" to get back to the part modeling environment (Part Studio):
