Expanding a female mold.
glenn_reed
Member Posts: 2 ✭
I'm not sure how to describe what I want. Need to cut mold oversized-Then coat 2mm with a stronger material and then recut to finished size. Can not use scale because centers also move. Best way to describe this is if I set up for finished size of mold but put in an oversized tool. Only surfaces get pushed out and centers do not re-locate. I'm creating curved foil shapes and I cant get face functions to work. Can any one suggest a way to accomplish this. Thank you
Will this be helpful?
In addition to the move face tool mentioned above, you might look at using offset surfaces as well. Also, when moving faces or offsetting faces, simpler geometry is easier to deal with. So, if you have complex fillets and things, it may be worthwhile to add those in after doing the offset operations.
Another approach might be to model the "molded" part, then scale that and use a boolean operation to create the female shape.
