Drafting - Dimensioning holes (diameter or radius) in parts with curved or spline driven surfaces.
In drafting whilst adding radius or diameter dimensions to views the software cannot detect radii and diameters on parts with curved surfaces or spline driven faces using the dimension commands. A simple example would be a hole in a cylindrical shaft.
Apologies if have have missed something obvious.
2
Onshape doesn't currently support dimensioning these edges. We're aware of this and I'll add you to that improvement.
As a workaround you can add a note to the edge.
_Dave_
Thanks.
