Ruled Surface Generating Lumpy Surfaces?
S1monS1mon Member Posts: 3,835 PRO
edited September 2021 in Product Feedback
I'm really happy that we finally have a Ruled Surface feature, but the quality of the surfaces is questionable. Here's an image of two surfaces, one is generated with a ruled surface with draft and one is a loft to an offset edge. Both are starting from the same ellipse trying to approximate the same thing. Guess which one is generating the lumpy curvature combs?
Now when I do curvature visualization (zebras) it looks fine. Is this an analysis artifact or is ruled surface generating much denser data with questionable rounding errors?
  • TimRiceTimRice Member, Moderator, Onshape Employees Posts: 315 image
    @S1mon
     I will pull a support ticket for this so we can take a closer look.
    Onshape, Inc.
