3 planes, 3 sketches, 1 shape...help?
Hey guys. Very new here. Sorry if people have answered a question like this before I've looked but found nothing that helped me!
I want to model an airplane. I have a three view drawing which was traced into a sketch.
How do I make a shape conforming to these sketches since they're on different planes? I can't seem to make the Use tool work or the Splines. Extrude can't handle all three planes at once and if I only extrude one side of one sketch I can't move the points to fix the shape.
I am just having a very hard time getting the program to do what I want at all. The 'best' option is to fill in the space I've already made, but if I have to build it from the ground up I can... not that I know how. If somebody could tell me a good procedure for going about this I would be very grateful!!
Pictures: the three sketches I have. I know it's hard to interpret what's going on so there's also a picture of the original 3 view. Right now all I'm trying to do the is the fuselage/body. Also shown are my attempts at selectively extruding/cutting the sketches. Lastly, my first attempt, which is considerably more of a shape, but doesn't have the dimensions I want and I can't figure out how to manipulate it correctly.
  • bruce_williams
    Hi @ella_eleven
    Welcome to Onshape and the Forum.  You are jumping in the deep end for an early design and have a good start in laying out the views in position. Make sure to go through the tutorials at  https://learn.onshape.com/ as they are excellent.  You will also find the help files very good.
    A couple of tips to get further - look at commands 'Projected curves' and 'Loft'.  A model design like the plane will use surface and solids, so things like 'Enclose' 'Fill' 'Ruled Surface' and the various 'Curve' creation tools.
    www.accuratepattern.com
  • ella_eleven
    ella_eleven Member Posts: 4 ✭
    That's fair... it's just that this is what I got into 3d modeling for, so duh I wanted to do it first. I'll work up to it.
    I figured out Loft with this guy, at least. as soon as i have more free time I'll do those other ones!
    thank you for the help!
