Change detection
fnxffnxf Member, User Group Leader Posts: 145 PRO
Just stumbled across this to me unknown trick, but which I figure a lot of us could benefit from: https://m.youtube.com/watch?v=v0jIoWxaG08
Very handy if you are using workspaces in your assemblies, and it’s become a mess. Did anyone else already know this? Thanks @Roy_Mutalik !
  • Roy_MutalikRoy_Mutalik Member, Onshape Employees Posts: 40 image
    @fnxf I'm so glad you found some use from this! I've definitely found it to be helpful, so I figured it was worth a share.
    The key to this trick is when you CANCEL the dialog as I did in the video. This causes the references to be updated in the active workspace where you are working (as shown). Note that if you actually SUBMIT the candidate, it only updates these references in the version/revision that is created as a result.
    Happy Release Managing!
  • EvanReeseEvanReese Member, Mentor Posts: 2,759 PRO
    I didn't know that either. Awesome tip!
