Onshape misses the second number/character typed in sketch dimensions
daniel_salleydaniel_salley Member Posts: 1
Hi all, i aware this might sound like a strange issue so please let me know if this is just a problem on my end. When typing dimensions quickly into a sketch feature Onshape constantly misses the second typed character. For example if i was typing 1.5, it would miss "." and i end up with 15 as the dimension, and if i intend to enter "15" i get "1". It happens 20-40% of the time. This is not a big issue but can break the flow of thought. This only happens on Onshape, not noticed it anywhere else on my PC, has anyone else seen this?
  • CBowersCBowers Member Posts: 50 PRO
    I always have some kind of input lag whenever I'm typing anything into Onshape. Sometimes it will actually type several characters, then shift back to right after the first character and start typing again.
  • raymond_russell588raymond_russell588 Member Posts: 2
    Similar problem with me. On my Chromebook, but not a Windows computer, I can't figure out how to change the dimensions of a shape due to changing a number with a ten's place. Not even 9. It won't show a typing blinky thingy at all. Although this is a similar problem, may not be totally the same.
  • The_M100The_M100 Member Posts: 20 EDU
    edited January 2025
    Try escaping the coincident constraint first. If you are trying to change the length, you need to click on the dimension tool first, then the line.
  • rick_randallrick_randall Member Posts: 418 ✭✭✭
    I have noticed this behavior while inputting data into configuration tables - I blame a slow internet connection firstly (worse at certain times of day), then I just learned to slow down while typing, by a micro second. Don't believe it's an OnShape issue though
  • martin_kopplowmartin_kopplow Member Posts: 1,322 PRO
    Also seen this at times, but I think it is a UI focus thing, not an OS thing.
