Adding Fillets
geoff_joseygeoff_josey Member Posts: 68 ✭✭
I thought I had got the hang of adding fillets !
On the att. model I am having a problem adding a fillet under the flange and also at the bottom of the well. On a simple test I created everything works fine. I think the problem may be related to the junctions between the revolve and extruded sections.
https://cad.onshape.com/documents/dbfa7cfd82c9a7f15e6226ff/w/d64b9ea193d295bb570aa317/e/ae4c646e8f30f9a135e8809e
  • S1monS1mon Member Posts: 4,083 PRO
    You have three separate parts. I’m guessing this is intended to be one thing? You need to “merge with all” during creation of the extrudes, or Boolean them together.
  • geoff_joseygeoff_josey Member Posts: 68 ✭✭
    I have just used Boolean to join the 3 parts and it is now possible to add the fillets. So easy when you know the correct procedure ! Thanks - I appreciate your help.
