Moving Multiple Attached Callouts
S_RegulaS_Regula Member Posts: 95 PRO
edited November 2021 in Drawings
We use a hexagon callout (without a leader) to indicate items that were changed with a revision. When we place the hex callout adjacent to the appropriate BOM balloon, the 2 appear to be "attached" when the mouse is hovered over one and the other is also highlighted. However, when the BOM balloon is moved, the "attached" hex callout does not move with it. Anybody else have this issue? Is there a way to ensure they STAY attached?? It's very frustrating having to move the hex callout after moving the BOM callout. TIA
  • PeteYodisPeteYodis Moderator, Onshape Employees Posts: 576 image
    @S_Regula Start a ticket with us and share the document with Onshape Support if you could.  Upon hovering with our Revision callout tool, we should be creating a group on the fly with annotations you hover over, and those groups should certainly move together.  You can also post select ungrouped annotations/revision callouts and group them after via the content menu command for "Group".
