hide BOM Item column in Drawing
randy_youngrandy_young Member Posts: 22 ✭✭
Is there a way to hide the "Item" column on a BOM when inserting onto a drawing?  I get that Onshape uses this row as a key so you can't remove the row, but when I have my own part numbers, I would like this to appear on the drawing without a confusing and potentially contradictory "Item" number listed.  Is there a way to hide it?  I'd even settle for a solid white, no-border rectangle to cover it up to make it invisible, but I can't figure out how to do that either.
  • PrachiPrachi Member, OS Professional Posts: 262 ✭✭✭
    Not possible at this time as far as I can see. Would also like to see that as an option from time to time.
  • AklamsonAklamson Member Posts: 2 PRO
    I would like to see this as an option also
