Dimension an angle from the end of a part
patrick_sheapatrick_shea Member Posts: 63 ✭✭
Showing a complimentary angle: How can I show the 33 degree complimentary angle? I want to eliminate the math to cut the end off.  I sketched a line on the Dwg, but can not measure to it.
Patrick
  • SethFSethF Member Posts: 132 ✭✭✭
    If you make a Sketch in the part studio, you can dimension from that. To show a sketch in your drawing, right click on the view, go to Show/Hide, then Show/Hide Sketches. From there you can select what sketch you want to bring into the drawing.
  • patrick_sheapatrick_shea Member Posts: 63 ✭✭
    TNX
