Showing 0 parts
neha_vutakuri402neha_vutakuri402 Member Posts: 1
Even though I made an object, it is saying that I have 0 parts and will not let me use it in the assembly. Help me with this issue!
  • cody_armstrongcody_armstrong Moderator, Onshape Employees, Developers, csevp Posts: 221 image
    @neha_vutakuri402 Are you sure you created a solid part?  If it is just surfaces you will not be able to insert it into an assembly.
    edited September 2015
    @neha_vutakuri402 , I think you have created surface part . Currently in Onshape user only insert solid part. There is one workaround If you want that part in assembly . Provide some thickness to that surface part with the help of thicken, extrude or revolve option. After that you can insert your part in assembly as shown in below video.
