How to trim an extrude
samuel_coleman349samuel_coleman349 Member Posts: 2
https://cad.onshape.com/documents/910479e3adea6ae11645a77d/w/dcd26666b8cca551e7450cb7/e/24d2b5826d60eff373ec1ff6 I am designing a pool skimmer flap.  Where the supports are I have created they extrude through the main surface to the outside.  I am trying to clear them off so they do not protrude, the front view shows them on the left side of the photo
  • bradley_saulnbradley_sauln Moderator, Onshape Employees, Developers Posts: 373 image
    Based on the view-only link you sent (can't edit or copy to edit) you can either use the Rib feature instead of the extrude or change the Extrude to an "Up to part/face". This would be the most efficient method to create the support structure. You could also just perform an Extruce > Remove on the profile the is hanging out to get rid of it as an extra feature.
    If you'd like more detailed help please share the document as Public so we can dig into the feature tree further.
    Twitter: @bradleysauln
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,509 PRO
    Changing the extrude end conditions as suggested above should work. If for some reason the face you need to stop at doesn't exist yet or you need to full length initially for any other reason, you could use a "move face" feature to bring the ends of the extrude inboard after the fact.
