Reposition Detail View (Drawing)
matthew_stacymatthew_stacy Member Posts: 489 PRO
What tricks are available to disable snapping, so that a detail view can be re-positioned in a drawing?  When I drag the view border center it automatically snaps back to the original position.
  • PeteYodisPeteYodis Moderator, Onshape Employees Posts: 567 image
    edited January 2022
    @matthew_stacy You currently need to drop the detail circle center on drag to an existing edge.  We don't have proper support yet for regions within drawing views - but we are working towards that.
  • matthew_stacymatthew_stacy Member Posts: 489 PRO
    @pete_yodis, thank you for the prompt and candid reply.  So the trick is that the center of the detail view must have a target to snap to and cannot float?
    I can see where there might be significant technical challenges in changing that behavior.  I can live with the current functionality as is.  Thanks again!
    @matthew_stacy
    If you don't snap the centre point when creating the view, you can then drag it around by the edge of it.
    IR for AS/NZS 1100
    @MBartlett21 thanks!
