Assembly constraints for basic blocks
hans_bollen
hans_bollen Member Posts: 10 ✭
Hallo Onshapers,
I'm new in Onshape and a professional mechanical engineer using 'other cad' for decades, Therefore, I believe I make good Onshape learning progress in one week of time. I know : Learning cad is both trial and error, and reading the manuals. Which really helps. But despite of and probably due to my extensive cad experience, I do not manage to assemble the shelfs in my birdhouse hbinb_00131. What I do expect is assembly constraints touch face to face and align face to face. With 3 of them I can constrain one plate to another. How to do this in Onshape ? I learned in https://learn.onshape.com/learn/article/mating-basics that I only need one mate action. Which one ? And how ?
Thanks in advance
Hans
  • Jake_Delano
    Jake_Delano Member, Onshape Employees Posts: 43 image
    Hi Hans. If you would feel comfortable sharing a link to your design, that could definitely help diagnose your specific issue. From what it sounds like, you are just trying to mate two parts together without any movement. In this case, I would suggest using the Fasten mate, which you can use to align your parts with one another and then add proper offsets if need be.
