Shortcut for closing out sketch and/or feature dialogue
wheeler_ganswheeler_gans Member Posts: 3 PRO
edited January 2022 in Product Feedback
I really miss the ability to accept/exit a sketch/feature dialogue without a mouse click. In SW this can be done with the rebuild command, but as far as I can tell in Onshape the only way to exit the dialogue is to click the green accept button in the dialogue.
  • romeograhamromeograham Member, csevp Posts: 740 PRO
    You can also right click>"Confirm <feature>" - click in the graphics area for this.
    Sometimes, if the wind is blowing just right, a simple Enter keystroke will accept the command and close the dialogue.
    Of course, if you want to accept this Extrude (Extrude 1) and perform another Extrude, you can type Shift+Enter and it will: accept this command, and open up the dialogue box again for you, ready for another extrude.
    I also missed the keystroke in SW!
  • Jordan_EnglundJordan_Englund Member Posts: 19 ✭✭✭
    In creo this is done with a middle mouse click, wherever the mouse is on the screen.
  • pharesphares Member Posts: 15 PRO
    edited September 2023
    A shortcut to exit sketches would be great. Ideally similar to Solidworks where you can double-click in white space to exit. The ESC key or double-tap spacebar would be good options as well.
