Controlling the axes of mates
joseph_newcomer
Member Posts: 101 ✭✭✭
I hit a problem where I created a slider mate, which was supposed to allow motion on the Z-axis, but instead the motion is on the Y-axis. As part of the dialog box that pops up, I should be able to select the axes of motion; I could select X or Y if I wanted, and one of these would surely work for the problem I'm having. The axis of motion should not be "wired in". In fact, I could imagine situations in which I needed a sliding mate in Z, and a sliding mate in X, and a sliding mate in Y. I apparently don't have that freedom of choice.
Take a look at this improvement request:
https://forum.onshape.com/discussion/16715/add-option-to-edit-mate-connectors-from-the-mate-dialogue#latest
This might be helpful for you.0
