Trimming Surface Results in Missing Edge/Vertex
ryan_kuhlenbeckryan_kuhlenbeck Member Posts: 1 PRO
Hello everyone, I am working with some surfaces in OnShape and am running into an issue that I can't seem to figure out.
I start with two intersecting surfaces that I trim using each other. However on one of the surfaces, the resulting trimmed edge seems to be invalid.
Unfortunately this is a work-related project so I can't share the model itself, but I can try to share as many relevant details as I can. I was wondering if this is something anyone has run into before? I've gone back in the feature tree to ensure all previous operations are OK and producing valid geometry, so at this point I'm not sure what my next steps should be.
  1. Intersecting surfaces https://imgur.com/11EnI7e
  2. Trimmed surfaces https://imgur.com/9gI3YGM
  3. Missing vertex https://imgur.com/wmnbJKR
  4. Missing edge https://imgur.com/BViKVGW
  • lanalana Onshape Employees Posts: 757 image
    @ryan_kuhlenbeck
    This looks like a bug. Please file an issue using "?"->"Contact support" menu and share the document with support.
