how to model that in onshape ?
Hello,
I couldn't find out how to build this in onshape.
Note : the draft won't work because the side of each tooth is parallel.
Thank you
Serge
Thank you
Serge
_Ðave_ Member, Developers Posts: 712 ✭✭✭✭
I believe that the rotate option in the move face command will work for this as in the following link.
https://cad.onshape.com/documents/98054ea36e1e4306858ea861/w/57381245ac76445886693133/e/4bc44f9ce3214404ad335d0d
5 -
Another (rather straightforward) way would be to sketch the profile equivalent to a section at the midplane, the use "Sweep" as a workaround for "Extrude at angle" in one direction from the midplane, then mirror the result about the midplane5 -
michał_1 Member, Developers Posts: 215 ✭✭✭
Hi, maybe I don't get something but geometry from first post you should get easili with draft:5
Thanks
https://cad.onshape.com/documents/a83345d4bdc74ca993f680d5/w/2caf6afc558b4a4385ee338e/e/bc1ad38b07514f12acbb989d
I also took the further liberty of extracting the Midplane profile from the solid shape resulting from his (modified) method, and derived those sketches into a second Part Studio to demonstrate my alternative "Extrude at Angle" method, and found it was not quite as simple in practice as in theory : I had to add a "Cut-Extrude" to trim the end.
Thanks, both of you, for the intriguing puzzle.
projektowanieproduktow.wordpress.com
I didn't look carefully enough at the OP's geometry but focussed on @DaVicki 's model - as michał_1 points out, there appears to be a draft angle on all four faces for the OP, although possibly steeper on leading vs trailing faces (but not a problem - just needs two draft features if so)
thank you so much
