skEllipticalArc between two points
arthur_peters
arthur_peters Member Posts: 19 ✭✭
Is there a way to have skEllipticalArc run between two points on the ellipse?
I already have the ellipse "description" (center, major, minor, axis) and the points that are on the ellipse (they are actually how the ellipse description is computed). However, I have not been able to figure out how to compute the start and end parameters for the points. I suspect the parameters is represented a fraction of the perimeter, but ellipse perimeter are terrible and I thought I would ask here before having to do numerical integration in FeatureScript. ;-)
PS: I'm doing ellipse fitting to points and tangents. I'm doing it directly since lofted surfaces seem to behave poorly when the provides use splines. I was unable to reliably use shell or thicken tools, even outward which should always be possible. Using approximations with circular arcs works better and I'm hoping ellipses will also work well and match my original shape better (an airfoil).
- Arthur (he/him)
  • Jacob_Corder
    Jacob_Corder Member Posts: 141 PRO
    you could create an ellipse and then use evDistance to get the start and end parameters. then use those. It would require either a sketch to delete or
    Try this. I havent tested it but it might work, it should work.  the only thing i am not sure of is if the ellipse wants arcLengthParameterization to true or false or if it doesn't matter.
     var stParam;
        var endParam;
        var startRef; //something to use to get the start param"
        var endRef; //something to use to get the end param"
        var majorRad =2*inch;
        var minorRad = 1*inch;
        var pln = plane(vector(0,0,0)*inch,vector(0,0,1));
        startFeature(context, id+"testEllipse");
        try
              var testSk = newSketchOnPlane(context, id + "testEllipse", {
                "sketchPlane" : pln
            skEllipse(testSk, "ellipse", {
                    "center" : vector(0, 0) * inch,
                    "majorRadius" : majorRad,
                    "minorRadius" : minorRad
            skSolve(testSk);
            var stDist =evDistance(context, {
                    "side0" : sketchEntityQuery(id + "testEllipse", EntityType.EDGE, "ellipse"),
                    "side1" : startRef,
                    "arcLengthParameterization":false
            var endDist =evDistance(context, {
                    "side1" : endRef,
            stParam = stDist.sides[0].parameter;
            endParam = endDist.sides[0].parameter;
        abortFeature(context,id+"testEllipse");
        var sk = newSketchOnPlane(context, id + "ellipseArc", {
                "sketchPlane" : plane(vector(0, 0, 0) * inch, vector(0, 0, 1))
        skEllipticalArc(sk, "ellipticalArc1", {
                "majorAxis" : normalize(vector(1, 1)),
                "minorRadius" : minorRad,
                "majorRadius" :majorRad,
                "startParameter" : stParam,
                "endParameter" : endParam
        skSolve(sk);
  • arthur_peters
    Thanks. I wondered about this. I just assumed that creating and destroying a sketch was absurdly more expensive than a bunch of math. I'll run with your recommendation. It's a good one.
    - Arthur (he/him)
  • konstantin_shiriazdanov
    This is some counterintuitive thing that you will find everywhere in featurescript, it turns out that often its quicker to reduce your computational math problem to evaluation on geometrical entities. This is mostly because those seemingly heavy abstractions are processed with highly optimized and performant core.
  • ilya_baran
    ilya_baran Onshape Employees, Developers, HDM Posts: 1,279 image
    For skEllipticalArc the "non-arclength" parameterization is the one you'd expect:
    R * cos(t * 2 * PI)
    r * sin(t * 2 * PI)
    As t runs from 0 to 1 for a full ellipse.  So no need for numerical integration; scaling, followed by atan2 is the thing to use here.  It should also be significantly faster than creating an extraneous sketch (if you already had an ellipse, it'd be faster to use built-in projection methods, but creating a new sketch has non-trivial overhead).
  • arthur_peters
    Does skEllipticalArc take an undocumented argument arcLengthParameterization? Or does skEllipticalArc use the "non-arc length" parameterization by default?
    - Arthur (he/him)
  • ilya_baran
    It uses "non-arclength" parameterization when specifying start and end.
  • arthur_peters
    Thanks!! This all works. I used it to do this: https://cad.onshape.com/documents/a3fa3ca417afcdc0464cda31/v/631d0a6f6b6a3e6203881d38/e/189464e90615c39820b70d1a I'm happy with it. No idea if it's actually useful, but it mostly works as expected. :smile:
    - Arthur (he/him)
