ASME Cold Formed Heads
digitalcarbondigitalcarbon Member Posts: 104 PRO
any "how to" on how to set up configs with formulas?
  • chadstoltzfuschadstoltzfus Member, Developers, csevp Posts: 168 PRO
    In variable fields, you are able to enter in formulas using FeatureScript syntax. A list of available math functions are shown here. You'll have to play around with parentheses (order of operations) and also attaching values onto these things. Also keep in mind you can reference previous variables when setting a new variable using the # sign. An example for h2 for the Flanged and Dished config could be
    #R - sqrt(((#R - #r) ^ 2) - ((#Di/2 - #r) ^ 2))
    chadstoltzfus@premiercb.com
  • digitalcarbondigitalcarbon Member Posts: 104 PRO
    ok, thanks. I will give it a try
