newSketch versus newSketchOnPlane documentation
marena_richardson
Member Posts: 20 EDU
The variable strangeness I was talking about earlier was in newSketch and newSketchOnPlane. Both take a variable called sketchPlane; only newSketchOnPlane says it does in the documentation right now, but they both do according to the starter code in the dropdown menu. However, as far as I can tell newSketch expects a query and newSketchOnPlane expects a plane.
You're right that this is more confusing then it needs to be, but your conclusion is correct: newSketch expects a query for a single plane, while newSketchOnPlane expects a variable with type Plane.
Since this is used so often, we're considering just merging these into one function, such thatnewSketch(context, id, {sketchPlane : p});will do the right thing whether p is a plane or a query for a plane.
Your thoughts on that?
I think that would be a great idea!0
