Modifier needed to remove a constraint from all selected sketch entities
The OnShape sketch user experience includes the ability for users to apply a constraint to all selected sketch entities. The sketch user experience should be extended to similarly enable users to remove a constraint from all selected entities using the same gestures but with a modifier selected when selecting a sketch constraint icon. The modifier may be a keyboard meta-key or some other momentary modal gesture. For example, when the current selection includes multiple sketch edges/curves, the equal constraint would be removed from all selection entities when the equal constraint icon is pressed while the remove-constraint modifier is simultaneously selected.
