Clutch Pate studio model corrected. DWT will not update to the corrected studio model.
rod_muirhead943rod_muirhead943 Member Posts: 96 EDU
Clutch Plate studio model was corrected.  The DWT will not place the corrected/updated studio model in the DWT.  The model sketch and extrude remove is corrected, but the DWT will not update.  I keep clicking on the yellow update icon.  In the DWT the R135, R128< and R118 are Not coming from the center of the spline circle.  In the studio I corrected the sketch and model.  The DWT is not updating.
What am I doing incorrect?  Thanks
  • Domenico_DiMareDomenico_DiMare Member, Onshape Employees Posts: 88 image
    edited February 2022
    Hi Rod,
    It's a little hard to tell from just screenshots what is going on. Generally, if you can, its best practice to make the document public and then copy/paste a link here. That way people can see what is going on better and make their own copy to try fixing it!
  • matthew_stacymatthew_stacy Member Posts: 489 PRO
    @rod_muirhead943, are Part and Drawing in the same document?  If the part is in "Other documents" (rather than "Current document") it may be necessary to version it after editing.
  • rod_muirhead943rod_muirhead943 Member Posts: 96 EDU
    Mr, Stacey,  Yes sir the part and drawing are in the same folder and document.  Thank you.  Still working on it.
