creating a sphere from this cube assembly.
paul_bartlett
Member Posts: 98 ✭✭
It should look like a Volleyball when done. I plan to make it from wood using the 6 sided cube I have created here. Then turn it on the lathe
I thought I could create my revolve profile on a center plane and use the revolve remove. I've been away for a while so need some guidance.
https://cad.onshape.com/documents/c9f4db24667e4db6cba38030/w/f217753909808d0510846e2f/e/1a19bd101faf022fd40bade5
See sketch3 and revolve1 in part studio1. I also had to adjust sketch4 as I had used this as the centerpoint but it wasn't actually centered... You're going to need to start with something a bit thicker this has holes in the corners as shown...
